MMBL question
MMBL question
MMBL question
Easy one guys. What does mmbl mean in relation to flow / consumption of barrels of oil. Is this million million barrels?
If so, what is the value in scientific notation as I think there is a diffence between US and European terminology for what a billion is.  ??
Kevin
RE: MMBL question
I think its much more common to find both "M" and "MM" used in Gas Flow, where "M" = 1,000 SCF and "MM" = 1,000,000 SCF, however it is also used for oil flow where "MBOPD" would indicate 1,000 BBLS per day.
I don't know the origin of the "M" designation.  It looks like it was derived from from Roman numerals, but then that would be an M for 100.  Anybody know?
BigInchworm-born in the trenches.
http://virtualpipeline.spaces.msn.com
RE: MMBL question
The "M" is the Roman Numeral for 1000
David
RE: MMBL question
BigInch's theory of the M being tied to Roman Numerals makes sense to me, but I have no idea why it would have been adopted as the convention.  In Latin (and in modern Italian) the word for "thousand" is "mille" and the Roman Numeral "M" was used for 1000.  BTW, the Roman Numeral for 100 is C, as in Century.
I have always taken the prefix "M" as being one thousand and "MM" as being one million, so I think the OP's question has been answered.  The most common usage I have seen of this terminology is in energy - e.g MMBTU of gas.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
RE: MMBL question
Guys,
The designation 'mmbbl' relates to Offshore Engineering magazine where it states new discoveries of oil reserves found globally in 2006. These are:
Shallow: 77 Fields @ 774 mmbbl Liquid Reverves & 527,258 bcf Gas Reserve.
Deep: 16 Fields @ 969 mmbbl Liquid Reverves & 9,600 bcf Gas Reserve.
Ultra Deep: 12 Fields @ 2,400 mmbbl Liquid Reverves & 3,100 bcf Gas Reserve.
Still not entirely clear how much this is but I presume it's a lot!
RE: MMBL question
Kander,
I must say that the designation preceeds the existance of Offshore Engineering Magazine by at least 3,000 years.
I'm not guessing, "M" as a unit prefix for "1,000" in Oil & Gas comes from the Roman Numeral.  My first boss had an Oil Field Geology text book from the 1890's.  Whenever someone would bring this up he would pull it out and there was a direct reference to MCF, MMCF, MMMCF (back then they didn't seem to use the BCF label), and MBBL and that the prefix was the Roman Numeral for 1,000.  I don't know of an older Oil & Gas reference than that one.
David
RE: MMBL question
zdas04,
So if M means 1000, this must mean that MM is 1,000,000 or 1000 x 1000? Is this the case?
So in the case of the above 774 MMBBL must mean 774,000,000 Barrels?
Also, I assume BCF means billion cubic feet?
Now, is a US billion the same as a European one? i.e. 1,000,000,000?
Someone told me otherwise (1,000,000,000,000)
RE: MMBL question
An EU billion is 1E+12, which is why the US trade deficit sounds so high.  Actually the Spanish language (as used in Spain), does not use the billion term at all, preferring to denote the number of thousands of thousands, such that 5E+9 becomes, "cinco mil de millones".  I believe the same is true for French, where even 80 is "20x4". In England,  however one billion has changed from 1E+12 and become 1E+9.  I don't know about use in Scotland and Wales.
This seems to confirm the above, http://mathforum.org/library/drmath/view/52579.html
The use of MM as a BOPD prefix for oil [red]flow[/color] is generally not used, since anything over 1 to perhaps 1.5 MMBOPD would be difficult to achieve in anything but the largest regional trunk lines.  I can't think of a single  instance where I have seen it used for oil, even for the very few lines in the world that can or eventually could reach such a capacity.
RE: MMBL question
kander,
MMbbl (million barrels) and bcf (billion cubic feet) are North American units for oil and gas, respectively. European units of measurement are based on the SI system. They usually refer to volume in terms of cubic meter (sometimes spelled as metre).
Here's an article explaining the history of the "barrel"
 http://www.slate.com/id/2115219/
Yes
Yes
Yes
As far as I know, the "common" billion (1,000,000,000) is the same anywhere. If you google for billion, you will find out that there is a "short scale" billion (1,000,000,000) and a "long scale" billion (1,000,000,000,000).  The former is the modern billion; and the latter is an old term and is rarely used (modern English language now calls this trillion)
RE: MMBL question
Let's not forget that the SI prefix symbol M means mega = 106, as in MHz or MPa; 109 = giga → G, and 1012 = tera → T.
Prefixes shouldn't be combined into compound prefixes, thus MM is not accepted; for instance, Tg should be used, while MMg should not.
SI prefixes are not to be used with oC.
In the U.S.A. 109 = billion, in other countries milliard.
In the U.S.A., 1012 = trillion, in other countries, billion.
When used as a physical or chemical symbol, M should better be slanted and bold M.
RE: MMBL question
It sounds like the billion = 1 x 10^12 (commonly called trillion) is longer used. Is this the case? Can you think of any industry where this is still used?
Surely any of the countries that have adopted the SI system would condsider a billion to be 1 x 10^9 ? A trillion 1 x 10^12 ?
Big Inch, the designation used for MMBBL is for approximate global reserves and understood probably not used in the industry that much.
RE: MMBL question
Yes, but you did ask, "What does mmbl mean in relation to flow / consumption", and reserves are differentiated from flow and consumption and indicating only a quantity.
RE: MMBL question
25362,
Roman numerals instead of SI causes some confusion, but not as much as you would think.  Many people wish the SI prefixes had been used by the old-time US Oil guys, but it wasn't and we seem to be stuck with Roman Numerals for volumes.  MCF, MMCF, MMBTU are terms that are reasonably unambiguous when discussing hydrocarbon production the world over.  The made-up unit of "therm" (I guess all units are made up, but this one feels phony to me) is becoming fairly common for gas consumption in contracts, but it isn't in common usage 25 years after it was proposed.
To say "MM is not accepted" flies in the face of its worldwide usage to mean "a thousand thousand".  You could say "MM is poor grammar" and you'd be right, just like you'd be right to say that "ain't" is poor grammar--that doesn't mean that the use of either vulgar term is not perfectly well understood.
I don't know how the term "billion" got so screwed up.  The oldest references I can find are pretty old saying it is 1,000 million.  The term "milliard" just seems odd to me and I've never heard it used in conversation in other countries, and it seems largely unknown in the US.
On the other hand, when I started in this industry the "unit" of "$M" was common and always meant "thousands of dollars".  Today it is really ambiguous and most people I deal with use "$k" to mean thousands of dollars and "$M" to mean millions.  People can evolve, but it is slow.
BigInch,
The DOE US and Worldwide statistics often us MMbbl to state imports, exports, consumption, and reserves of crude oil. I sometimes see it in company annual reports and SEC 10K reporting.  I don't see it much in talking about individual plant or flow line capacity.
David
RE: MMBL question
Yes, I totally agree it is commonly used for oil reserves and import statistics, but the original question was flow related, which (to me) implies a continuous flow pipeline capacity, as opposed to batch imports via VLCC.  I am only saying MM is not a commonality for oil pipelines, due to the rarity of size of a system needed to deliver such quantities, however "M" BOPD is most certainly in common usage.
RE: MMBL question
kander,
In my humble opinion, the term "billion" when associated with oil or gas reserves is equal to 1,000,000,000, regardless of units (i.e. bbl, cubic feet, cubic meter, tonnes). I have read some articles where they mentioned "trillion cubic meters of gas" or "trillion tonnes of oil".
Why dont you post in forum470 to get some more feedbacks (or confusion). Also ask the math forum for your "billion" dollar question : )
cheers
RE: MMBL question
zdas04, when I said MM is not accepted, I thought it would be understood:... by the International System of units (SI).smile
RE: MMBL question
Sorry, I didn't get it.  I envisioned the thought police running rampant through the Oil & Gas industry.
David
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
RE: MMBL question
mmscfd is common for gas transmission pipelines.
Regardless of SI, metric, imperial, there are still many industries that use their "historical" units of measure.
For example, shoe sizes.
Within an industry, units are used frequently according to custom rather than any one system. It is very common, for example, for someone in my industry to refer to pipe sizes in inches, pressure in kPa, gas volume in mmscfd, and liquid voume in bbl. It's just the way it works.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: MMBL question
Ashereng,
The first time I heard a Canadian ask for 3,000 meters of 2-3/8 inch tubing I cracked up.  Now it just sounds normal.  Canada is the only place I've heard E3M3 for gas volumes, but at a class I taught up there last month everyone understood MMCF's just fine.
David
David Simpson, PE
RE: MMBL question
zdas,
Come over here and you'll find not only M3 for gas, but also tons/year for oil flowrates... and they don't admit to understanding CF, however BBLS is OK, but we're digressing now.
RE: MMBL question
Tons is fine, tonnes is fine, as long as everyone understands how many molecules there are in one unit.  On the phone I always ask if the "ton" mentioned is 2,000 U.S. lbm or 1,000 kg.
David
RE: MMBL question
Thanks David. I forgot we also use E3M3. I guess it's a Canadian thing, eh?
rofl
Albert Einstein
RE: MMBL question
Kander:
In the oil refining business, M=1000 and MM=(1000)(1000) = 1,000,000 (one million in the United Sates).
We would not usually refer to oil quantities as MMBL ... instead we would much more often use MM BBL, meaning 1,000,000 barrels of oil.
I million = 1,000,000 = 106 both in the United States and in the UK.
1 billion = 1,000,000,000 = 109 in the United States but, in the UK, 1 billion = 1,000,000,000,000 = 1012.
Many European countries follow the UK convention, but not all ... so be careful to ask what a European means by 1 million or 1 billion.
Beware of India, a billion can mean many, many different things there.
Milton Beychok
(Visit me at www.air-dispersion.com)
RE: MMBL question
mbeychok,
Being a UK resident I'm quite sure that a billion means 1,000,000,000. Certainly where I was taught.
UK follows SI units and has done since the late 60's (I think), but there seems to be a little confusions as to where the billion = 1x10 ^ 12 is used. I can't see this being the case anywhere in Europe.
Any ideas?
RE: MMBL question
kander,
YOU are the ONLY ONE confused. Why are you making a big fuss on semantics? If you have doubts on terms containing "billion", ask the source of that information. You will probably sound stupid to them, but at least you will have the satisfaction of knowing that the billion means 1,000,000,000.
RE: MMBL question
Kander,  You are right in that many other places in Europe you don't find the problem at all, but its because the billion (1E+9) term does not exist those languages.  Spain, for example, where 1 billion, 1E+9 is called 1,000 "miliones" and a trillion is a million millions.
RE: MMBL question
kander:
I am an American who lived and worked in London for 8 years in the late 60's and early 70's. At that time, the billion in the UK was 1012. The UK had not yet metrified. There were still 12 shillings to the pound sterling.
Now that England has metrified, the billion may now be 109 as you say.  If so, then I stand corrected.
If anyone wants more information as to which countries use which definition of a billion, I recommend reading:
http://en.wikipedia.org/wiki/Long_and_short_scales
Milton Beychok
RE: MMBL question
mbeychok / BigInch,
Thanks for your help with this one. Quite interesting the different views from around the world on the definition of a billion.
Cheers,
Kander
