Photoworks Material Applying Problems
Hi All,
I'm having some Photoworks issues. Photoworks won't let me apply materials to part faces in an assembly. I remember older versions of SW let me do this.
I don't want to have to open each part file individually to apply these changes. I've tried clicking on the "apply material at part level" but I'm still not able to filter part faces.
What gives?
Specs, Intel Pentium M 2.16 Mhz
SW 2007 R2.2
1.5 Gb Ram
NVidia GE Force GO 6800 256Mb
RE: Photoworks Material Applying Problems
I have never seen this in an assembly only if you are editing the part in the assembly. SW07, SW06 and SW05 only allowed you to add a material on the part in the assembly.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
FAQ731-376
Apparently you have to "clear selections" in the object selection window before you're given the filtering options in Photoworks.
SW 2007 R2.2
1.5 Gb Ram
