Diverting runoff from a natural seasonal spring
I understand that sizing the pipe/channel will depend on the expected quantity of runoff.  I'm interested in some feedback from anyone who has taken on a task such as this.  I have had a wetland delineation made for the area and it has been surveyed.  I'm interested in BMPs for diverting a spring into a wetland channel.
Thanks for any thoughts
RE: Diverting runoff from a natural seasonal spring
The BMPs would be a swale or pipe.  Pretty easy.
The permitting required to not go to jail for doing that will be monumentous.  Start w/ your state/provincial Environmental regulatory agent.  If you are in the US, you will also need something for the USACOE.  I'd bet in any other country, there is a similar, federal agent.
Engineering is the practice of the art of science - Steve
Thanks for your comments, LHA.  I've had a wetland specialist delineate the area and received fill permits from our Department of State Lands and COE.  I don't believe that DEQ gets involved unless you eject into the ground.  I imaged the same as you suggest with a perimeter swale to collect the runoff and culvert to convey to a proposed outfall.  I was interested to hear if anyone had other methods.  Also, estimating a quantity of flow from the spring is somewhat sketchy to me.
I would be more concerned with the department of water resources as this may require a claim of water rights
Piped with rock at outfall should be an option, water rights notwithstanding.  If you use a surface channel make sure the bottom is adequately sealed (e.g. use a liner if sandy soil) so that you won't lose your water through infiltration before it reaches the wetland.
What about the Watershed district that this will drain to?
Richard A. Cornelius, P.E.
WWW.amlinereast.com
