Compress Z axis
Compress Z axis
Whenever I start-up Compress my Z axis is pointing down instead of up, is it supposed to be up? If so how do I change the orientation so that it is up. Thanks.
RE: Compress Z axis
I personally prefer datum at the bottom. In this case the datum will regularly "drop" to the bottm as the vessel model is constructed component by component. This can be disconcerting to some people. I sometimes get vessel files at Codeware where users have elected to have datum at the top. I suppose the users like to have a "fixed" datum that doesn't move on them.
The 3D graphics used by COMPRESS has a "light source" to create shadows and highlights. There are differences in light and shadows between datum at the top or bottom and the graphic may look different. There is no real benefit to selecting one datum over the other.
Tom Barsh
Codeware Technical Support
RE: Compress Z axis
Though the Datum line will not bother the vessel dimensions and other factors, I too prefer to have the datum at the bottom, so that the Z-axis points upwards.
Aravind Sujay
