Process Engineer: Design eng vs System eng.
First off, I am not sure if here is right location for my question, please correct me if I am wrong. The question is:
In some companies the duty of process engineer is splitted to two areas: process engineer that does design and sizing and process engineer who is expert in developing P&ID (they name them system engineer).
Some other companies disagree with that and expect a process engineer does both duties.
What do you think? How popular are these two options? Which one is better from your point of view?
Thanks for all replies
RE: Process Engineer: Design eng vs System eng.
It really varies, both from company to company and from person to person.
I do know that some larger companies have a separate "systems" group that develop P&ID.
Most process engineers though, with some experience, I would expect to be able to do both. On large jobs, of course, there would be more segregation. On most medium and smaller jobs, I would expect it to fall to the same person/group.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I've worked in mainly smaller companies, the largest was about 400 in the top Fortune 500.  As process engineer I did all sizing of equipment including valves and controls, all P&ID generation,all process chemistry & thermal, simulations, Process economics and finally material selection/specifications.  My duties included Project Management of up to $10MM before it hit the PMO level.
