NPSHR testing
NPSHR testing
Hi, Can anyone advise if there is a general requirement to individually test the NPSHr for each pump of a batch of pumps when undertaking the head / capacity testing?
Is it acceptable to base the NPSH values on calculated values and evidence from previous similar pumps that were tested?
any advice welcome, thanks.
RE: NPSHR testing
RE: NPSHR testing
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
RE: NPSHR testing
After some testing they learned which manufacturers could be trusted and which ones 'pushed the envelope'.
rmw
RE: NPSHR testing
