Revision Block Control Macro
All,
I've put together a Revision block control macro called RevBlockControl that allows the user to control the adding of new revisions. Hopefully this will help many people save time. Also, feedback is welcome (that's why I'm posting here). I intend to add functionality as time allows.
http:/ /sw.fcsupe r.com/inde x.php?name =UpDownloa d&req= viewdownlo addetails& amp;lid=65
Use in good health. :)
http:/
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
RE: Revision Block Control Macro
http:/
These are the references already selected;
http://
What's missing?
SW07-SP3
Matt
Silicon Valley, CA
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
Thanks. :)
Matt
Silicon Valley, CA
SW07-SP3
1. LENGTH CHANGED.
2. VIEW D REVISED.
3. DIMENSION "1.0" WAS "1.5".
Thanks!!! So you are one "those", huh? :) I'll look into it. There's a limitation on how VB forms handle inputs with carriage breaks. It's allowed if you enter in the ALT-code, but I'm on a laptop today, so I cannot test how this works in the RevBlockControl macro and how it talks to the Revision Table (no numeric keypad, the the Fn button seems limited in scope when trying to use it for the fake laptop numeric keypad). There's two ALT-code's you can try...line break and carriage return. I can't remember the codes off the top of my head, but someone should be able to list them.
As far as long term, I can look into providing a method for multiple lines. At this moment, it looks like I can add a button that lets you insert line breaks? I'm not sure how I'd handle the preview though.
BTW, I'll be uploading a small update later today to fix a small error I found in the execution of one of the options. It will be available at the same link above.
Matt
Silicon Valley, CA
Eric
I implemented your request. The new version is at the same link above. Enjoy!
Matt
Matt
Silicon Valley, CA
