Live Trace Adobe Illustrators VEctors into SW?
Hi all! this forum rocks btw...
so my latest question is regarding adobe illutrator files.
I want to use the live trace feature of Adobe Illustrator to make vectors in illustrator and then to use those vectors in SW to make a sketch. Is this possible? I havent tried yet because Im busy with another project right now but its def been in the back of my head to figure out if thats possible and how? thanks in advance! -ethan
RE: Live Trace Adobe Illustrators VEctors into SW?
Be aware though; You will not be able to use nested closed profiles in a SM part. SW does not support multi-body sheet metal parts.
SW07-SP3
The tool works great. The only other problem you may run into is that somtimes closed vector loops may not come in as closed. This happens very rarely and is usually when the ai files contain very large sketches or very small line elements.
RFUS
The nice thing about SolidWorks is that there are normally lots of ways to do whatever you need.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
SW07-SP3
