409SS weld then forming problems
                    Weld seam cracks after roll forming a flange.
                    Process: Rolling a cylindrical tank with 14 ga 409SS sheet and
                    using SAW for the butt weld seam.  Filler is ER309LSI and flux is
                    ST-100.  After the seam weld, a .4" deep flange (rough cross
                    section below) is roll formed on the top edge of the tank.  The
                    weld is so brittle it cracks at the stressed corners.  I am getting
                    mixed info on pre- and post-weld heating.  One says to use low
                    heat input during welding and form at room temp without
                    annealing.  Another expert suggested pre- and post-weld
                    treatment.  If heat treatment is recommended, can heating with a
                    dull grinder be effective?  Any other suggestions?  It would be
                    nice if a ductile filler for 409 and 304 could be found.  Thanks in
                    advance.  SCOTT
                                                     |____
                                                      ____|
RE: 409SS weld then forming problems
The welding process and filler selection will somewhat alleviate your problem, but I'd say offhand that you will get best, quick results from annealing the weld affected zone prior to forming. You are losing all the ductility in the heat affected zone from the welding.
Would suggest you visit www.nidi.org and look through the technical info you can download there.  Among several items on welding of stainless steel,  I recall # 10,014, #1208 and #9002.  You may find others by using the search engine available on the NiDI site.  Good luck.
Thanks for the NIDI source - doc 9002 has some good SS info.
