Point animation. Where is the dimension??
Hi all
I'm trying to animate a point moving along a spline path. I have the point mated to the line and set to a percentage constraint. I have all my display settings turned on but I can't make the percentage value display so that I can edit it? All of my other sketch dimensions display when I click on parts
Is there some weird display setting I'm missing.
Specs, Intel Pentium M 2.16 Mhz
SW 2007 R2.2
1.5 Gb Ram
NVidia GE Force GO 6800 256Mb
RE: Point animation. Where is the dimension??
"percentage constraint" ???
Dimension ?? DT ?? Equation ??
cheers
SW07-SP3
Sorry for being unclear.
When you insert a reference point you can set the location as a percentage along the line you place it on. Then you can set an equation up so that the percentage value increments each time you rebuild the assembly.
SW 2007 R2.2
1.5 Gb Ram
Ah exactly.
SW 2007 R2.2
1.5 Gb Ram
