Planned vs Actual Bars with % Complete
Is it possible to show planned vs. actual bars with % complete in the Gantt view?  If so, will this include a projected % complete based on the baseline?  If this is possible, how do you do it?
RE: Planned vs Actual Bars with % Complete
If you populate the %complete column, you should see a black bar overlaid on the plan bar.
TTFN
Eng-Tips Policies FAQ731-376
Simply clicking on the Tracking Gantt view will give you the current information, the baseline information and the % Complete.
I do not believe it is possible to show the % Complete of the original baseline.
Hope this helps!
J Black
www.pmconnection.com
I'm populating the % Comp column, but it is not overlaying the shading on the stask bar.  Any ideas/help?
