Material for high temperature service in SO2 gas
Hi:
 I need some help to choice a better resistant material for a butterfly valve that is a bypass  valve for recovery boiler ( gas side) in the sufuric acid production, these are the conditios:
 Combustion gas with 12% SO2( 79% nitrogen ,9% oxigen) at  1120°C (From the suphur burn) , 31 f/s(average) , in a duck work , 34in of diameter.
The last material that we use was Haynes 556 , but had a catastrophic failure las february.
 Now we use  temporaly, SS 310S, but we want to choice  hayness HR 160  or Supertherm( duraloy trademark) .
Can anybody help me to choice or suggest a better material?, Thanks.
RE: Material for high temperature service in SO2 gas
Austenitic stainless steel types 321H or 347H and nickel base Alloy 600/600H and Alloy 800/800H might work.
HR-160 is the most sulfidation resistant grade that I know of.
One thought would be to use a 310 valve and have every surface coated (weld overlay or HVOF) with Ni-Cr.  Without looking it up I recall that 50/50 gives good resistance
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
