Mazak 0.50 MS cut conditions
I'm having trouble cutting 0.50 mild steel w/O2. After I pierce and begin cutting, my cut is very rough (welds itself back in) for the first few mm. Then it stabilizes and cuts well. Any suggestions or cut conditions for the beginning of the cut? I'm using an older 2K mazak. Thanks!
RE: Mazak 0.50 MS cut conditions
To do this, you have to break the geometry of the part, assign the cutting parameters mentioned earlier and just before program transitions back to normal cutting, use the parameters you have been using all along for cutting this material.
Example:
G00X1.0Y1.5
G82P2000Q10R35(Pulsing Condition)F3.5
G01x1.060Y1.5
G82PxxxQxxxRxxxF35
Good Luck
