Impact Testing Welds in Duplex and Super Duplex
Is there any benefit in impact testing welder qulafiction procedures in these materials? The process duty doesnt go below 10C or above 45C. The requirement was found in a specification and I dont want to propogate a myth.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
RE: Impact Testing Welds in Duplex and Super Duplex
I assume that you are concerned by the impact test requirements and also exemptions allowed in the ASME VIII. Try to review the clause(s) UHA-51. Obviously, it's totally different for structural applications.
Cheers,
gr2vessels
I can understand the ferrite, hardness testing and corrosion testing of the test welds but impact testing was unexpected?
If your corrosion test is actually a corrosion test and not a check for intermetallics, then you may want to do an impact. I would do them cold, -40. Look in A923.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
No. Perform the corrosion test if you have concerns.
If it is intermetallics, then a low temp impact can tell you the same thing.
The test in FeCl to detect intermetallics is not a corrosion test per se, it can only be used for microstructure evaluation.
Rust never sleeps
• ASTM G48 method A
• Exposure time shall be 24 hours
• Specimens shall be full thickness
• Sample shall include the weld orientated n the transverse direction in the centre of the sample and the sample shall include both heat affected zones and associated unaffected base metal
• All surfaces shall be exposed
• The sides only may be ground to a 600 grit finish and the edges may be rounded
• Samples shall not be pickled and passivated prior to test
• Test temperature for UNSS31803 weld samples (22% chromium duplex) shall be 20ºC
• Test temperature for UNS S32750, UNS S32760 weld samples (25% chromium super duplex) shall be 40ºC.
• Acceptance criteria-No pitting at 20X and maximum weight loss shall be 4.0 g/m2
At minimum you should move to the G48 practice C for the test solution. It is more stable and repeatable.
Are there exceptions for end grain type of attack?
Has all of the plate been qualified at higher temperatures?
You are exposing the as-welded faces in an attempt to show that the CPT exceeds the test temp.
At the same time you are looking at the edges trying to detect intermetallics.
It isn't that you can't do it this way. It is just like making sure that your impact tests for A923 also meet the requirements for UHA-51 (always use -40 or colder and always measure lateral expansion). It saves testing time and costs
You need to just keep in mind that the test might be severe enough to detect intermetallics, but is it a good CPT verification?
What test was used to qualify the plate? Higher temps than these I hope.
Rust never sleeps
I have seen these requirements before, but never for a desalination system. They were specified for specific refinery/chemical plant applications and oil/gas gathering/processing systems. There was some early (20-27 years ago) real concern that the welders would not satisfactorily implement the WPS, which was qualified with additional corrosion tests and impact tests before A-923 came into being; also the ferrite number at the root of the pipe welds exposed to the corosive media could not be verified. As a result additional training and qualification testing was mandated to assure that welders would weld to the WPS.
Your specification requirements appear to be hold over from that earlier time period.
Many thanks for your input.
The specification I suspect is a cut and paste from a previous project and the history before that is unknown. Like many specifications its antecedants are lost in time.
I shall get hold of A923 and read up on the requirements there.
The material is pipe not plate and has been specified as ASTM A 790-S31803. No additional testing has been specified other than required by this standard. Coupons are to be cut from the pipe for testing.
I would like to be able to see a specification for a desalination plant and compare the requirements. I have checked the Norsok site but could find anything there. Is there a website you could recommend?
Your material should be S32205, not S31803. All of the better mills work to the restricted chemistry, but you never know.
A923 should be required on the tube/pipe as well.
Rust never sleeps
I would suggest that you consider using the A923 test, either FeCl or low temp impacts to qualify the weld procedure (and each welder).
The procedure is a bit different from your spec. I suggest that you get a copy and compare.
Rust never sleeps
The way NORSOK deals with duplex piping materials (not welders) can be found in:
http://www.standard.no/imaker.exe?id=3789
Steve Jones
http://www.pdo.co.om/pdo/
Rust never sleeps
Steve Jones
You are paying for corrosion resistance, you should test to see that you are getting it. If the procedure is robust enough then it should be no problem for every welder to qualify. I don't see that this is any different than weld RT.
Rust never sleeps
Welder qualification is what it is, the ability of a welder to demonstrate that they can produce a weld of acceptable quality/workmanship, and follow directions. The welder qualification does NOTHING beyond this. The WPS provides the necessary technical basis for welds used in service with impact testing or corrosion testing requirements as part of the engineering design specification(s).
Welder RT is what it is, the welder can produce an acceptable quality weld following a qualified welding procedure. Making welders jump thru additional hoops is costly and serves no useful purpose.
Since corrosion in a SS system will almost always be localized (pitting or crevice) and the welds often are the weak link in corrosion resistance, then it stands to reason to be concerned about the specific location of 99% of your corrosion issues.
Certainly different weld characteristics need to be treated differently depending on Code requirements, but in concept I don't see verification of corrosion resistance (in this case actually microstructure) as being any different from verification of size, strength or soundness.
Rust never sleeps
One can always specify above and beyond minimum Code requirements for welder qualification. I am more of the opinion that you have your ducks in a row for the welding procedure specification, and taken into account corrosion issues on the front end.
We are dealing with 75 bar pressures. A jet of water at this pressure would cut you in half.
I tend to agree corrosion is as equally important as strength. The Codes & Standards are quiet on many things that the committee doesnt understand or cant agree on.
