COPY SETTINGS WIZARD
solidworks crashed during a session and when I restarted, all of my customized settings were gone.  I tried to reset them with the copy wizard, but then remembered I never copied them due to some error message I got when I tried to copy them to the "wizard" when I installed the new version.
After rebuilding all settings I again tried to use the Settings Wizard to copy the toolbars and such (again).... and I get this window that says, "cannot load Solidworks settings information from "administrator".
I'm running SW on a stand alone machine, 2007 sp 2.1.
I saw Scott's FAQ559-1158 but not sure there's help there for what I'm describing.  Thanks for any follow up.....
John
RE: COPY SETTINGS WIZARD
Check with your VAR, but I think you can rename (and delete later) a registry setting and restart SW to regain your settings.  I don't remember what the setting to rename is, but your VAR should know--or maybe it's buried in one of the FAQs.  Don't rename anything in the registry unless you know what you're doing.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
That FAQ should still work. but only if you have the file.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
FAQ731-376
