Linear load on composite deck
I am looking at an existing composite floor, a concrete slab on steel deck, to carry mobile selves which run on tracks. The deck is designed for 195psf and the tracks have a weight of 1000 pound per linear foot . How would you check this floor for this type of new loading. The tracks are 72" apart and run in the direction of the flutes of the deck.
RE: Linear load on composite deck
htt
You would probably want to check the shear capacity of the deck, too. The United Steel Deck Manual has a good example of this.
