Gasket in Spectacle Blind
Can anyone tell me if do I need to replace the existing gaskets installed between the spectacle blind and flange when I rotated the spectacle blind? The line will be pressure tested thus, I need to rotate the spectacle to close the line.
RE: Gasket in Spectacle Blind
A piping flange gasket that has had its clamping/compressive force removed should be replaced.
An exception would be metal ring joint gaskets that can be reused under certain circumstances.
I agree with dtn6770,
You should always replace the gasket with a new one when you "break" a flanged joint.
Ditto, I'm also in agreement with the above replies.
NozzleTwister
Houston, Texas
Thanks guys!
