you can't beat helium test if you n
you can't beat helium test if you need it,
if the hydro were strickly a leak test, then you would not need the pressure it requires, and even then it would only tell you if the blind flanges are made up correctly...
RE: you can't beat helium test if you n
So, comparing hydrotesting to helium leak tests is like comparing apples to grapefruit.
