desolve pattern and or mirror parent child relation
I'm trying to mirror features of in a part to keep from having to redraw them. After I mirror them I need to move them a little. Can this be done?
RE: desolve pattern and or mirror parent child relation
You should be able to copy and flip the feature sketch though, instead of doing a mirror.
Also, non-merged features (a body in a multi-body part) can be mirrored and moved using the Move/Copy Body function.
SW07-SP3
Thomas Stover
You can move the mirrored geometry by using the Move Face command (Insert, Face, Move). If your geometry is simple enough this should work for you.
SW07-SP3
I've recently developed a fondness for the Move/Replace Face commands. I've always liked the option to Delete Face and have the model auto-magically patch itself but I just used the Move / Replace commands on a recent project. They made it a lot easier to end up with a part that wasn't cobbled up with a lot of features that were simply there to clean up some geometry that resulted from some differing draft angles on a molded part. Fortunately, these commands are intuitive enough that someone else can pick up the part at some point in the future and easily see what was done.
SW07-SP3
If you want to modify the base shape of the feature, then copying from FM tree method would be best.
SW07-SP3
