Equations Operators
Equations Operators
Equations Operators
Hi all
Just wondering what an easy way to perform an odd or even check would be in the equation editor.
eg. if "xxxx" is positive then ....
               else  negative then ....
Specs, Intel Pentium M 2.16 Mhz
SW 2007 R2.2
1.5 Gb Ram
NVidia GE Force GO 6800 256Mb
RE: Equations Operators
The iif function can be used to return different values based on a condition.  So to get a different value if xxx is odd than if it is even try:
CODE
iif(("xxx" mod 2) like 0, even_value, odd_value)
Eric
