Routing - Piping - Trying to Use Custom Components
I am trying to modify my options in routing so I can choose a PVC elbow fitting instead of the default. I have created the fitting but am not successful in using it because of a "no valid configuration could be found for this elbow" error. Can anyone tell me what routing is looking for to establish a link between the pipe and and fitting?
RE: Routing - Piping - Trying to Use Custom Components
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
Did you purchase SolidWorks Premium to get Router?
Bradley
SolidWorks Professional x64 2007 SP3.0
Intel(R) Pentium(R) D CPU
3.00 GHz, 3.93 GB of RAM
Virtual memory 12577 MB
NVIDIA Quadro FX 3400
Zuccus
I have a Tee. When I drag the tee onto a 1 inch pipe it shows the default configuration of 1 inch (there are 10 or so configs from 1/2 to 10 inch but they are not showing unless i check show all configs). This is what I want to happen.
What is confusing is if i open the tee and edit the cpoint1 feature, make no change, and save the tee it no longer loads to the correct config (it will show all 10).
Any thoughts?
regards,
www.scottjbaugh.com
FAQ731-376
I contacted my VAR and he was able to locate the following SPR#,
SPR# Description Status Comments
358194 Configurations on fittings made in 2007 are not filtered Implemented 2007 SP03
I will be installing SP3 today, hopefully that will work.
www.scottjbaugh.com
FAQ731-376
I do not know for sure about the location of the clip. I only saw the demo. We are thinking about upgrading for the same reason as you.
See if you can see this webcast from GoEngineer on SolidWorks Routing.
http://66.89.101.227/web6/tips.html
Bradley
Bradley
