Is there any Law documentation?
I was wondering if there is any documentation out there that shows the proper law language and syntax. I don't currently have a knowledgware license so I am looking to try to build some intelligence into my models using laws instead of rules. I come from a UG background and Catia seems to do this a bit different than I am used to. Any help would be greatly appreciated.
RE: Is there any Law documentation?
And for the formula editor as well. For example, can you use IF statements in the formula editor itself, or just in a law?
I hope someone knows where to find this information.
I have a habit of asking questions before giving answers, because I find that more information leads to less "discussion", and more direct results. So if I could be so bold - could you elaborate a bit more on your objective, before being referred to the documentation?
I am asking primarily because you speak of "language" and "syntax" with laws, which leads me to believe that you may be trying to do something that is not suited to their application.
Catia Design|Catia Design News|Catia V5 blog
Be careful not to mistake "laws" for "knowledge laws". I thought you were trying to use the law function to accomplish this on your first post.
AS for the documentation - I looked into buying several Knowledge Products recently, and was mortified to find out that it was challenging, if not impossible to self-train on these products. In fact, the reseller told me that they usually won't sell KWA and KWE without the purchase of training. (not offered through them, but through Dassault) The API for KW products is not included in the documentation, and your guess is as good as mine as to where to find it.
Hope that helps. (though I doubt that it does)
Yes. Look for boolean parameters when you are setting up the design table. The parameter labeled "activity" controls activation or deactivation of features via a true or false setting.
I have done some pretty cool "knowledge" products through nothing more than than just HD2 and a good working knowledge of Excel formulas.
PKT and KWA is a very awesome combination of products. If you ever get into knowledge processes, these are the 2 to have.
Good luck.
