DRAFT / SHEET (Drafting workbench)
Hello Gang,
Within the DRAFTING workbench, what is the difference between a DRAFT and a SHEET?
Or is there such a thing as a DRAFT?
scott
RE: DRAFT / SHEET (Drafting workbench)
Are you talking about Catia V4 or Catia V5?  What are you basing your question on? (do you have a specific scenario, or are you asking about terms you heard used)
Catia Design|Catia Design News|Catia V5 blog
A V4 "DRAFT" is the equivalent of a V5 "SHEET". Both are the same thing as a piece of paper containing the views of a mechanical drawing.
In V5, I've only seen the term "DRAFT" used for angled faces on molded parts. Have you seen it in the Drafting Workbench?
jackk - "Draft" appears (in the tree) when you import the V4 model containing the 2D "paper" space - the same way "master" appears when you import 3D geometry.  I believe that it also names the sheet as "Draft" when you paste the V4 geometry into a CATDrawing.
Hi there Guys,
solid7 - I am talking about CATIA V5 only.
jackk - you have stated exactly what I thought.
Thanks both for your inputs. This is a confusing issue for me when going from CATIA V4 to CATIA V5.
Scott
