Shock Spectrum
Shock Spectrum
Shock Spectrum
Folks-
Our customer has imposed a shock spectrum on the laser product we are developing for him.  How does one go about approaching such a problem with pencil and paper? Spreadsheet? MathCAD? FEA?
I know this is a wide-open question but perhaps if someone could just point us to a practical reference I'd be much obliged!
Tunalover
RE: Shock Spectrum
Thanks GregLocock-
Thanks but I suppose I should have mentioned the word "free" reference.
Tunalover
RE: Shock Spectrum
There's a free 7 day trial.  Get a work experience student to take screen shots for 7 days LOL.
RE: Shock Spectrum
The free trial allows you to download any and all PDF files you have access to.  Unfortunately, it's PDS (PDQ-not), because the files are arbitrarily sectioned.
TTFN
Eng-Tips Policies FAQ731-376
RE: Shock Spectrum
IRStuff and GregLocock-
Why do you refer me to FAQ731-376?
Tunalover
RE: Shock Spectrum
We don't.  It's part of our signatures.
TTFN
RE: Shock Spectrum
We're not picking on /you/ tunalover, we pick on everyone!
Cheers
Greg Locock
RE: Shock Spectrum
Thanks guys.
I have a copy of Harris but it's hopelessly buried in a box in my garage.
Good Luck!
Tunalover
RE: Shock Spectrum
The shock response spectrum gives the peak acceleration response for a single-degree-of-freedom system subjected to base excitation.  The natural frequency of the item is the independent variable.
You can readily determine the item's peak acceleration for a given natural frequency from the SRS plot.  The key is that the natural frequency of item must be known through analysis and/or test.  Upper and lower esimates of the natural frequency may be used if the natural frequency is not precisely known.
The relative displacement might also be a concern.  The relative displacement is approximately equal to the SRS acceleration divide by (omega sub n)^2, where (omega sub n)is the natural frequency in terms of radians/sec.
On the other hand, a given item may behave as a multi-degree-of-freedom system.  There are some techniques available for applying the SRS to such a system.  A finite element analysis is usually required to carry this out.
My favorite method is to synthesize a sample time history to satisfy the SRS.  Then perform a modal transient analysis via FEA.
For further information, I have posted a free SRS paper at:
http://www.vibrationdata.com/tutorials2/srs_intr.pdf
Additional, papers are available at:
http://www.vibrationdata.com/SRS.htm
Thank you,
Tom Irvine
