FLUE GASES DUCTS: ROUND vs RECTANGULAR
Where can I find guidelines or can someone advise on the issue of the duct shape, in our case the cross section of the required duct is 3.25 sq.meter.
regards,
roker
regards,
roker
RE: FLUE GASES DUCTS: ROUND vs RECTANGULAR
In a rectangular duct, it's slightly easier to fabricate a short radius bend ... not that a short radius is a good idea.
I wonder if anyone made flues rectangular before the appearance of baghouses, which tend to be rectangular for more defensible reasons.
Transitions, e.g. from rectangular baghouse apertures to round ducts, are a little harder to manufacture than simple joints. They're harder to draw, too, which may be the real reason rectangular flue ducts first appeared.
Mike Halloran
Pembroke Pines, FL, USA
https:/
As you can see from the above, I would suggest some research on the subject. There is much more information.
Also check for guidelines from the environmental agency in your jurisdiction, like EPA (http://www.epa.gov) in the US.
Here's an interesting read... http://rmb-consulting.com/san/rectduct.htm
