Block Edit Problem
Block Edit Problem
I am having a strange problem when I use refedit to edit a block. When I edit the block and save the edit, the block scales itself to some random scale(always smaller) and is moved from it's original location. I can get around it by exploding the block, but I'd like the get to the bottom of it.
Thanks in advance.
Thanks in advance.
RE: Block Edit Problem
Powerhound
Production Supervisor
Inventor 11
Mastercam X
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
http://mechcad-insider.blogspot.com/
"The fear of the Lord is the beginning of wisdom"
The block is not nested under anything else. I created it using copy, paste as block.
