v4 files need to view in v5
Can I view .exp file in catia v5? (.exp was imported from catia  v4 file)
I know that .model can be easily view in catia v5 system.
But, currently my hummingbird system is not working & the only file i can make out of v4 is .exp.
Does anyone have suggestion?
RE: v4 files need to view in v5
search the forum, you'll find out what to do with EXP file in order to see them in V5
Eric N.
It's a long time since i've used V5 but there is a command in the tools that appeared sometime around release 11 which is to extract model from sequential batch.  Hope that helps.
Tools - Utilities : Import or extract Sequential file (something like that anyway)
Don't forget to rename the file so it ends with .exp at least I have to do it every time.
