wood shear wall
wood shear wall
When designing shear walls in beach houses, the ocean side is almost always full of windows & doors. Making the numbers work is not too big of a problem, I'm worried, though, that when there's no panels meeting the IBCs 3.5-1 height to width ratio, that the panel will not be able to develop the shear resistance. This seems to only be a prescriptive restriction, but I cannot find any books, tech bulletins, etc. that address wood alternatives. (Steel would work but I'd only get one job in my career). Does anyone have any resources or advise? These houses are very common and being new to engineering them, I'm having a tough time. Thanks for your help.
RE: wood shear wall
RE: wood shear wall
http://www.eng-tips.com/viewthread.cfm?qid=174585
RE: wood shear wall
RE: wood shear wall
RE: wood shear wall
In reference to using the perforated option. As in my original post, I can make this "work," the numbers aren't too bad, especially by sheathing inside and out of the wall. I just can't find any reports about using wood shear panels (except Simpson and others), that have aspect ratio's greater than 3.5:1. I'm having trouble convincing myself that this is okay.
Thanks again.
RE: wood shear wall
http://www.awc.org/Publications/download.html
Towards the bottom under the "Technical Articles and Papers by Others" heading is a section for Shear Walls with lots of papers for perforated shear wall testing.
Also, I'm a little confused that you mention using wood shear panels with an aspect ratio greater than 3.5:1, because shear wall aspect ratios greater than 3.5:1 are never allowed. I hope that you mean that your full height wall segment aspect ratio is greater than 3.5:1, whereas your wall pier aspect ratio is less than or equal to 3.5:1 in your perforated shear wall. It's my understanding that the force transfer (blocking and strapping) around the openings is the key to make the perforated shear wall act as a unit as opposed to the individual wall segments.
RE: wood shear wall
