Inland Underwater Pipe Installation
I am working on a budgetary cost estimate (apx 30%). I have to deliver 250 cfs of water out of a river appx 3 miles to the toe of a dam where it will attach to and outlet from the downstream side of the dam through a sluice pipe. About 2 miles is under about 100 feet of water in a long, narrow reservoir, located off Hwy 70 (a long windy road) in the Sierra Nevada mountain range (CA).
I would like to know what equipment (along with mobilization and construction costs) will be necessary to lay the pipe on the bottom, which will require some dredging to keep a consistant slope for gravity flow. There is about 100 feet of head.
Thanks.
RE: Inland Underwater Pipe Installation
Clam-shell bucket with barge mounted crane,($2500/day plus mobe).
Re "pipe on the bottom, which will require some dredging to keep a consistant slope for gravity flow."
You don't need a constant slope for gravity flow. Can go up & down by siphon effect (as long as no significant leaks).
The section of the LA Aqueduct, completed ca. 1913 (some work continued to 1916):
'The south end of the Jawbone Siphon, an 8,095 foot steel pressure siphon.'
Kenvlach
On land air release valves are placed at high points. They are not normally used underwater due to maintenance considerations. Therefore it is advisable to have a fall, albeit not constant, underwater.
UConDoIt
Use a HDPE pipe with concrete weight collars, which can be launched as it is welded together and then installed by the S-Lay or Float Flood method. Being in a reservoir you will not need very big collars as the wave forces are low.
Stephen Argles
Land & Marine
www.landandmarine.com
