O-Ring Squeak
O-Ring Squeak
I have an existing product which uses a Buna-N O-ring to seal two ZAMAK components that rotate relative to each other. The O-ring seems to have a squeak during rotation: I've used PTFE & silicone lubrication to eliminate the noise but was wondering if changing the O-ring material would help. Anyone have any experience in this? Thanks in advance.
RE: O-Ring Squeak
You didn't tell us what you're trying to seal, so we can't comment on what seal materials or lubricants would be appropriate. Your Parker rep or distributor can.
www.parker.com
.. no affiliation, just decades of experience, with them and the other guys.
Mike Halloran
Pembroke Pines, FL, USA
RE: O-Ring Squeak
RE: O-Ring Squeak
All elastomer material is not the same. Just because you call it Buna-N, do not assume it. Compounds can very greatly and have the same hardness. When spec'ing/ordering, look at both the Shore A hardness and tensile strength. Suppliers often only talk in hardness.
Tolerance on the parts is also very large. A ptfe option may be something to consider. Assuming you are using a dashed unsplit o-ring. The ptfe may need to be replaced more frequently from cold flow, but will also act as a dry lubricant. Just a thought. However, this depends on parameters such as temps, speeds & pressures.
As discussed in earlier threads, do look at the dimensions, both theory and actual and also try without the o-ring as earlier recommended.
Surface finish where o-rings ride should also be inspected/reviewed.
Cheers,
MECOMAN
RE: O-Ring Squeak
Seal what?
At what differential pressure?
Rotate at what speed?
One direction rotation or both direction?
Continuous full rotation or part rotation (fewer than 360 degrees?
Temperature?
Environment?
