OPENING PRO-E PART FILE-NOTHING HAPPENS
I've had this problem with a couple pro-e part files from different customers. I try to open it, "xxx.prt.1", The "Pro/Engineer to Solidworks Coverter" dialog box comes up. I change the radio button from analyze the model completely, to import geometry directly, with knitting, and try forming solid model checked, hit Ok. The Pro/Engineer to Solidworks Converter" , that analyzes the file, comes up for a quick flash, then dissappears, and that's the end of it. No model, not even an empty part file comes up. I'm on sw2007 sp2.2. Is proe locking us out?
RE: OPENING PRO-E PART FILE-NOTHING HAPPENS
Solidworks 2007 SP2.0
2GB Ram/3GB Switch
Quadro FX1300
P4 3.40GHz Duo XP Pro SP2.0
http
I downloaded this file and went to open it and the file name is cap_w_drive1a.prt.1.txt.
Reaper.
It downloaded and opened without any trouble for me with SW07-SP3
htt
Could the files you are getting be WF 3.0 files?
Would explain why CorBlimeyLimey can open the files.
Anna Wood
SW 2007 SP2.2, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
