Nozzle order in VDP - Nozzles not in numerical order
When I go into VDP I notice that the nozzle schedule shows the listing of the nozzles all scattered around, not in numerical order, is there a way I can get the nozzles to come out in numerical order rather than all scattered around?
RE: Nozzle order in VDP - Nozzles not in numerical order
Hope this helps?
This problem has been reported to our program development list and it should be addressed soon. Sorry for the inconvenience.
Tom Barsh
Codeware Technical Support
Bob, I tried the steps that you outlined and when I hit ok after entering my changes this is the error I get on my AutoCad command line:
Command: ; error: bad argument type: FILE nil
I have VDP build 5.53. I've noticed some other things that cause it show errors also, like when I go to do vortex breakers and davits. Any ideas? Maybe this is some of the things Tom had mentioned.
I suggest sending a description of the error messages to our support at codeware.com e-mail address and we will review. You may want to update to the newer build 5514 first (available on our website).
Tom Barsh
I updated to the new build and I still get the same error. I'll send it to the support and see what they say. Thanks.
Correct the problem by checking the file properties for file "vdpsetup.txt" located in the VDP folder. Uncheck the "Read only" setting if it is checked. Normally, VDP is installed into folder c:\Codeware\VDP.
There are several other text files in the same folder with "txt" file extensions. If similar problems occur with NIL errors or unsaved settings, then set these files also to allow them to be written to.
Tom Barsh
Find your vdpsetup.txt file and right click with your mouse and go to properties at the bottom of the pop-up, there you will see whether or not read only is checked or unchecked.
Generally, you can "right click" the mouse cursor on the file in Windows Explorer, then select "Properties" from the pop up menu. Make certain that the file's "Read-only" "Attribute" is not "checked". You may need to ask your IT department for assistance on checking or changing the attribute (an Admin log-in account may be required).
Tom Barsh
