0-5 vdc to 0-10 vdc question
I have a analog output from a plc which is 0 to 5 vdc. I am driving a dc drive which has a 0 to 10 vdc input. My drive is now only seeing half speed. What is the fix and where can i get it.
RE: 0-5 vdc to 0-10 vdc question
dydt
work but you will need a supply hooked to the op amp of at
least 10VDC (probably more unless get rail to rail op amp).
If this is a problem (no 24VDC available or 12VDC) then a DC-DC converter may work. This would depend on how quickly the changes will be occurring but would not likely cause a problem.
Verify as well, that there is not a jumper on the plc card that allows you to change to a 0-10 vdc signal. Quite a few analog cards have this capability.
IMHO, I would get a signal conditioner or just change the card to a standard 0-10 vdc signal. Do not create a potential hassle for you later. Redlion and Action Instruments have fairly inexpensive condtioners.
Carl
