How do you know if a problem is "linear"?
How does one go about determining if a structural problem is linear or non-linear? People talk about "large deflection", non-linear materials, etc. but there have to guidelines somewhere! What if one assumes a non-linear problem is linear and uses a linear FEA code? Will there by any indication that you've gone down the wrong path or will the code give you misleading answers?
Tunalover
RE: How do you know if a problem is "linear"?
It depends on the type of problem. Consider a few examples.
If you have cables with catenary action, pretensions, etc., you obviously have a nonlinear problem, right?
If you have a 3 story bldg with concrete shearwalls, you have a linear problem unless a specification forces you to do a nonlinear analysis. Then you'll have a nonlinear analysis that gives you the same result as a linear one, LOL.
If you have a steel frame, you probably have a nonlinear problem just because the AISC Spec forces you to do a nonlinear analysis. Your answer will be slightly nonlinear.
The bottom line is that you have to understand the program you're using and its limitations. Some use things like consistent geometric stiffness matrices. Some don't. Some iterate by updating these matrices. Some iterate by changing geometry. It is very possible to mis-use a program, especially when dealing with very nonlinear things like cable nets.
Sorry for indirectly answering.
I don't think your question has a standard "good" answer.
2.71828
Generally speaking if a member has deflected twice it's depth, it is non-linear behavior. Obviously there are a multitude of examples where this isn't true. Concrete or brittle material is one such exception.
Concrete strains are limited to ensure the correct behavior under service conditions. Anything beyond 0.003 and you've cracked the concrete and begin yielding reinforcing. This can be at a very small deflection limit compare to that of a steel beam. Yet it is considered to be non-linear behavior.
Check out texts on non-linear behavior and or Elasticity where in your more likely to find some general guide lines. Refer to texts on the materials themselves to understand the limits of linear elastic behavior.
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
There are many other examples and cases of nonlinear behavior. The best thing to do would be to find some texts that will explain things more in depth.
Dik
By "do twice as much," I assume that you mean "apply twice as much load." If it deflects twice as far, then all that means is that the model's PREDICTION was linear. For example, I can put a cable net into a linear program and run it subject to 1 kip. I can change it to 2 kips and will get twice as much deflection, which is obviously wrong.
Dik
