Too Much Reinforcing in Concrete Wall?
I am working on a WWTP where the precaster would like to keep a wall thickness to 14". I can make this thickness work for the loads, however, the reinforcing is becoming quite heavy on the inside face mat. I would need to use #9 bar @ 4" o.c. Although this still falls below the maximum steel ratio and the spcaing of the bars is wide enough to allow the largest aggregate to easily pass through I am having concerns about this configuration. What are your thoughts? Is there a good reason that I should insist on going with a thicker wall?
RE: Too Much Reinforcing in Concrete Wall?
I suppose I could go to a 10 bar but I understand that they are much harder to find in our area and the precaster does not stock them.
Thanks for the quick response!
After talking with the precaster it sounds like we have the option to go with a ribbed wall as well. This may actually be a cheaper option than this heavily reinforced flat wall.
Thank you all for the input.
Besides, in no different in you providing a design for a contractor to build. The contractor has a responsibility to build it correctly, per your design, just as the precaster is responsible for his quality control.
PMR06, not all precasters have the ability to use prestressed or post-tensioned tendons in there products. As an engineer though, you should encourage your precaster to explore prestressing and post-tensioning. There are many benefits to using these methods.
For f'c=5ksi and fy=60ksi, I come up with a rho max (or 0.75 rho balanced) of 0.0252. You are right, his rho is 0.021, but it is not over-reinforced.
The tensile strain is 0.0051 so 10.3.5 isnt violated.
