Vbelt
Vbelt
can we replace touthedbelt with Vbelt ( ofcorse we must replace all component if it's possible)how to verify this possibilité
RE: Vbelt
The obvious answer is yes, of course you can.  The real answer requires a bit more detail as to what the intended use and loadings are.  Is timing/index  of concern? Are there space limitations? Is noise a concern?  etc...
It has been in my experience that the trend is away from v drives and not the other way round.
Keep in mind that a smallish Gilmer type toothed belt will transmit a great deal more power effectively than an equally sized v belt drive.
Rod
RE: Vbelt
Vendor-supplied application engineering manuals provide excellent information on this.  Gates.com is what pops into my head, there are plenty of others.
TygerDawg
