Best Stainless Steel for Marine Application
Can someone suggest the best grade of stainless steel for use in a marine environment? Parts are not submerged. Some are turned, some are springs; low cycle life.
RE: Best Stainless Steel for Marine Application
Good luck.
Rayband
RAYBAND
Rock Island Arsenal
AMSTA-RIA-SEM
http://
For springs you need to use even more corrosion resistant materials. No 300 series stainless is suitable for high stress use in a salt water environment. Maybe a 6%Mo stainless (AL-6XN) should be considered.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
