REX 42 or REX T15 Tool Steel Heat Treat Data
I'm looking for heat treat temps and property data to see if these tool steels can withstand a 900 deg. F coating treatment without destroying their RC 65-67 hardness. Where or from whom can I find property data?
rayband
RAYBAND
Rock Island Arsenal
AMSTA-RIA-SEM
RE: REX 42 or REX T15 Tool Steel Heat Treat Data
We cycle both materials to 900/1000 F hundreds of times with no loss of physical properties. Some of the T-15 material is 30 years old with thousands of heat cycles and is in a very demanding service as gear pump shaft.
These two pages will lead you to all the information you will need.
http://www.crucibleservice.com/eselector/prodbyapp/highspeed/highspeedapptitle.html
http://www.crucibleservice.com/eselector/prodbyapp/tooldie/t&dapptitle.html
Unclelsyd,
Thanks for the fast response.  Your comment and the links gave me all I needed.
rayband
RAYBAND
Rock Island Arsenal
AMSTA-RIA-SEM
