Trumph 380 Controller
I have a Trumph 380 Laser with a TASC 500 controller.
I need to send CNC data from our eXtreme CNC program to the laser via db25 Serial connection and/or the on-board floppy.
The on-board floppy does not respond so I replaced the 1.44mb drive to no avail. I suspect the daughter card is bad as a result. (This would have been an alt option anyways if the serial connection went down.)
I cannot find the pin-outs for the serial connection  anywhere. I've tried std 2-3, 3-2, 7-7, 6-20 but no go.
Can someone please help me with this delema? I need the pin-outs of the serial connection and a spare floppy drive assembly if possible.
Thank you in advance.
