Assembly to Subassemblies
I have built up a system in an assembly. It contains all discreet parts, all started from the assembly. These can be grouped (and for ease I have group them in folders in the assembly tree) as Outer Tank, Module, and Lid.
Two questions:
Can I make a subassembly with all the same links and associations from the parts in the assembly tree without having to drag and mate them all into a new assembly file? I would like to do this for the three groups. I tried to select some and hit make new assembly, but it just gave me the whole assembly.
Can I Save this assembly (Asmb 1) as is and copy save it to a new assembly so that I can break all links wile having the first assembly that I can always go back to. If so, what happens if a change a part in (Asmb 1), will it change in (Asmb 2), or will it prompt me to rename the part?
RE: Assembly to Subassemblies
You will be notified if certain mates will be broken, sketches lost, etc).
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Several components can be selected.
