Subassembly modification
Say I am building a box out of separate parts (not molded). I would have bottom, sides, and front and back. I would like to radius the sides of the finished box, but the parts files should remain non radiused. How is this done. Ideally too, I would like a subassembly of the fabricated box with out the radii, as it might be on a manufacturing shelf this way.
RE: Subassembly modification
Or do you mean bend the side plates into a curve?
In top view, it would be a rectangle with radiuses on each corner. Depending on the size of the material the sidepieces may or may not be effected. Generally they would not though. If this were a molded box, the outer edges of the box would have radii running upward.
