Texture issues in 2007
Hello all,
I have been having lots of issues with SW 2007 sp2.2 textures. When I apply them to components, I can not seem to remove them. If I apply it at the part level, it disappears when I insert it in an assembly, and so on. At this point I am fed up with the situation and would like to just remove all the textures from the parts and assemblies period. The remove texture button is not active so i can not use it. Does anyone have a macro for removeing all textures that I could try?
Is it just me with these issues or is anyoone else experiencing the same thing?
Thanks.
BB
Thanks.
BB
RE: Texture issues in 2007
http://www.moderntechmech.com/support/macros.html
Chris
SolidWorks 07 2.2/PDMWorks 07
AutoCAD 06
ctopher's home (updated 03-13-07)
Side note:
Other things have started to happen as well. The "Remove Textures" button became active and when I removed all the textures from the assembly it also changed some of the components to hidden. I went and changed their state to "Show" and they appeared with the old texture and when I run the cursor over them the components disappear and reappear when the curser is no longer over them. Sorry for the run-on sentance.
Is there a way to record a video clip of what is happening on my screen?
Using this tool gives a quick what's-what at the assembly level and can be really helpful.
"Using this tool gives a quick what's-what at both the part and assembly level and can be really helpful."
Gotta give you a star for that. Thanks
BB
