New 22" FP monitor
New 22" FP monitor
I would like to get a 22" FP for SW and was wondering if anybody had any recomendations. I can get a Dell E228WFP at a reasonable price
http ://accesso ries.us.de ll.com/sna /productde tail.aspx? c=us&l =en&s= dhs&cs =19&sk u=320-5205
I use 2 monitors and would also use a 19" FP maybe a 20" would be ok instead of the 22. Suggestions?
Thank You
http
Thank You
RE: New 22" FP monitor
http://
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Some things to keep in mind regarding monitors:
Viewing angles (go for wide, horizontal and vertical)
Big contrast
Quick refresh rates
Gray color display (HUGE factor in my decision--I render a lot and cheap LCDs cannot compare with the old 21" ViewSonic CRT I used to use as my primary monitor--I recommend viewing a monitor "in real life" before buying)
Jeff Mowry
After working on this monitor a while, I'm now used to the more "sharp" display of an LCD, but every time I pass by cheap monitors in the store I really cringe--that gray-black issue is very bad in most of those displays.
Another test--check out the darker regions of an image at a slight angle to the monitor and see how quickly the detail becomes lost in those regions as you increase your angle.
This particular Gateway I'm using was expensive when I bought it (maybe still is), but it's about the only feasible LCD I could find that would handle my qualifications.
Jeff Mowry
Chris
SolidWorks 07 2.2/PDMWorks 07
AutoCAD 06
ctopher's home (updated 03-13-07)
24" provides much more area then the 21" does. 3" may not be much, but it is when you use 1900 resolution.
Good luck,
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
I got 2 19" flat panels & FREAKIN' LOVE it.
Windows XP / Microsoft Wireless Optical Mouse 5000
SolidWorks 2007 SP1.0 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
FAQ376
Chris
AutoCAD 06
CJ Goodrich
Product Design Engineer
Leatherman Tool Group
Portland, Oregon
Chris
AutoCAD 06
