3-Sided Box Lateral System
Does anyone have link to a technical resource for designing a “3-sided box” lateral system.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
3-Sided Box Lateral System3-Sided Box Lateral System(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: 3-Sided Box Lateral System
It also states that you can not have a cantilevered wood diaphragm that is supported on masonry or concrete shearwalls for seismic (NDS 4.1.5) but there is no provisions for wind loads.
If you are going to keep the 3-sided box determine if the the diaphragm is flexible or rigid:
if it rigid, distribute the loads according to wall stiffnesses. Pretty much all the shear will go into the wall parallel to the applied load and the moment will be resolved into the walls perpendicular to the load.
If it is flexible you are out of luck.
The American Plywood Association has a free download for diaphragm design (L350) just go to there website.
I hope this helped
Dik
