Why design a joint to be partially restrained?
What is the advantage of designing a joint to be fixed as opposed to being pinned?
What is the point of patially designing a joint?i.e for instance allowing a column to be free to translate in the z direction while being fixed in the x and y?
RE: Why design a joint to be partially restrained?
As far as column translation, a column should almost never translate in the Z direction except for the column shortening due to axial load. One reason you might restrain translation in the Y, but not X, direction is because a column's strong axis is the X axis and, as a result, can have a greater unbraced length and achieve the same axial load capacity as the shorter unbraced length in the Y direction.
I am not sure this was asked in your post, but just FYI, there is also a great advantage to partially fixing moment connections in steel frames. You can use top and bottom angles to create a semi-rigid frame, that will yield under gravity loads (and the beams and girders can be designed as pinned-pinned), but are still capable of resisting lateral loads. The interstory drift is about 1.5 times that of a rigid moment frame, but this is a much less expensive and more easily fabricated connection detail.
If you do not understand the fundamentals, then you should do some reading. This forum is no place to learn structural fundamentals.
