CompactLogix: how to change the IP in MSG? SSV?
I have a CompactLogix L32E.
I want to use the MSG instruction with more than one IP address.
so, i need to change the IP address/path in the MSG.
I haven't been able to find an example.
Would i use SSV?
RE: CompactLogix: how to change the IP in MSG? SSV?
I want to leave the IP of the Eth port as is.
I just want to change which device i communicate with.
http://rockwellautomation.custhelp.com/cgi-bin/rockwellautomation.cfg/php/enduser/std_adp.php?p_faqid=17521&p_created=932483666&p_sid=AGAA*Cwi&p_accessibility=0&p_lva=32420&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTEmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5hX2lkJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9MTc1MjE*&p_li=&p_topview=1
i can give you an example acd, but how do i upload to this site?
Simple solution:
Use two or more message instructions, one for each target device.
I can't create one MSG for each destination.
That could end up being 50 to 100 IP's.
thanks,
