yet more ISO tolerancing
3
I know the ISO tolerancing thing has been discussed to great lengths here but......
I have a 120n6 mm shaft and a 120H7 mm bore.
The website below describes the tolerancing a little differently than what I have read before. Here is how they describe it.
120n6 shows as +45 and +23 in micrometres.
   First limit is 120+0.045 = 120.045mm
   Second limit is 120+(0.045 + 0.023) = 120.068mm
   So the limits are 120.045 and 120.068.
120H7 shows as +35 and +0 in micrometers.
   First limit is 120+0.0 = 120.0mm
   Second limit is 120+ (0.035 + 0) = 120.035mm
   So the limits are 120.0 and 120.035.
Is this correct?
http://www.roymech.co.uk/Useful_Tables/ISO_Tolerances/ISO_LIMITS.htm
Thanks.
RE: yet more ISO tolerancing
no,
the shaft has a double plus tolerance and are not additive
meaning 120.045 to 120.023 120 plus .045 and 120 plus .023
bore is 120.000  to 120.035
ie may be a pressed fit at max material conditions.
3
Check this web page:
http://www.tecnologix.net/en/tools/passungsrechner/passungsrechner_v05.html
click on "Fit Calculator" and enter your ISO tolerances.
Dimjim is right, your tolerances should look like this:
   Second limit is 120+0.023 = 120.023mm
   So the limits are 120.045 and 120.023
   Second limit is 120+0.035 = 120.035mm
Gearguru,
Thanks for the url for the fit calculator.
Nice fit calculator (* for u)
Kevin Hammond
Mechanical Design Engineer
Derbyshire, UK
How is it that a shaft 80h7 can enter a bore 80H7 with what is described as a "loose fit"?  Can't they theoretically be the same size - 80.000mm - with zero clearance?
Software For Metalworking
http://mrainey.freeservers.com
Yes, they can. But statistically how often it happens?
To control the loose fit it is better to select one of the parts H (h) and the other g, f, e... (G,F,E...)
The "farther" from H (h) toward A (a) is the second parts tolerance, the more guaranteed clearance the fit has; and the opposite is valid also - the closer toward Z (z), the more interference in the fit. The number in the ISO tolerance description (like 8 in the H8 tolerance)  controls the total tolerance, the letter the location of that tolerance relative to the nominal size.
I use this ISO-tolerance calc. Nice to have on your desktop (excel-sheet). In Swedish though, but you will figure it out (haven't had the energy to translate it).
http://www.megaupload.com/?d=WEQV0MOC
