PDMWorks temp view file post check in
Guru's,
I have always had some difficulty getting the temp view files on a multiple sheet .slddrw
to show up proplerly in the PDMWorks viewer. Most times there is an issue with a section view or detail view not showing up. Recently I discovered that my temp view files were not updating. The following describes the event:
1. first check in of drawing.
a. right click on the newly saved file in pdmworks vault view and click "document properties".
b. Notice that a view is missing.
2. Attempt to repair the drawing view by:
a. flipping the line of sight arrows back and forth (or other tricks/workarounds).
b. check the file in (as I thought it would show properly)
3. repeat step 1a...repeat step 1b-cuss.
Can any of you please direct me to a work around or a fix for this problem?
Is there any way to force a temp view file save?
Is there a discreet button that I've forgotten to check.
Version of SolidWorks: 2006
SolidWorks Sercive Pack:sp4.1
Operating System & Service Pack: win2k v5 (sp4)
Graphics Card and Driver version: Nvidia Quadro fx540, 7.1.8.4
Amount of installed RAM: 1GB
Virtual Memory settings: APPS, total paging = 1024mb
CPU Type & Speed: intel pent 4 / cpu 3.00GHz
RE: PDMWorks temp view file post check in
Chris
SolidWorks 07 2.2/PDMWorks 07
AutoCAD 06
ctopher's home (updated 03-13-07)
I agree. Pdf's are the best way. I still am waiting to see if this works better with 07. Our company just got swallowed into a larger corporation and we are behind with the 07 install. I was assured by my var that this was fixed in a further sp than what I use. (V6, sp5 or something). Glad to find out that somebody else has tried to whip the old mule into shape along side...Sorry to hear that such a powerful tool lacks in delivery at your company as well. Was a serious problem for us. Sure hope it is fixed.
dsgnr1
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
