Callout Precision
Callout Precision
Any idea how to change the precision on a callout? I'm new to SE and I can't get the Mass to show anything other than 0.0Kg in the title block, when it should be 0.013Kg. I'm sure there's a way, but I can't figure it out.
Paul.
Paul.
RE: Callout Precision
use %{Mass/@3|R1} the digit after the '/@' specifies the number
of digits to show
dy
besides those found within the callout panel I found only the
one already given: /@n. This will work only for those items
that are defined as numeric. When using it in conjunction with
a Custom variable make sure it's defined as numeric otherwise it
won't work.
dy
found some more, excerpt from SE Help "Create Property Text"
Including Other Text Properties
To use the date and time in property text, use the following basic format:
/@<date/time format> Click here to see additional information on available
formats for date and time components. You can customize date and time
display using the following format: %{propertyName/@DateTimeFormat|link}
For example, to display the exact time a file called Lea.asm was created,
you can use the following: %{Created/@yyyy/MMMM:dddd-hh_mm,ss.tt|Lea.asm}
You can use property text to control the number of decimal places in numbers.
For example, to set a number to display 4 decimal places, use the following format:
%{PropertyName or CustomPropertyNumber/@4|ModelRef}
You can choose not to display default units for physical properties.
To omit units from the property text display, use the tag /NU as follows:
%{PhysicalPropertyName /NU | R1}
dy
