Split Part alternatives. Creating Assembly Out of Bodies
Just curious as to any ideas out there in regards to creating assemblies from part files made from multiple bodies.
Is the Split Command the best tool to do this? What about when the part file are exceeding 100Mb?
Specs, Intel Pentium M 2.16 Mhz
SW 2007 R2.2
1.5 Gb Ram
NVidia GE Force GO 6800 256Mb
RE: Split Part alternatives. Creating Assembly Out of Bodies
With this method, you don't have to define boundaries along which to split up your part. Also, I think you may reduce your overall file size, but each part will still refer to the original multi-body part--and any changes you make to the original part file will be reflected in the saved-as-part files.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
That's just the answer I was lookin for.
Cheers
SW 2007 R2.2
1.5 Gb Ram
